1-1-2007 |
7.00 |
Brake/rudder pedal assembly |
- Riveted together brake pedals. - Assembled pedals w/ master cylinders onto rudder pedal bars. Found that one left pedal didn't clear the attachment and had to file it down slightly then reprime to get enough clearance to insert a washer and still have free movement. - Drilled out F6116 side bearing blocks for bolts |
