Date:    12-27-2006
Number of Hours:    2.50
Brief Description:    Forward bulkhead fitting
- Adjusted the F902 forward bulkhead flanges to set perpendicular to longitudinal axis of aircraft. Fluted as needed. - Clecoed and drilled the F7101 Gear Attach Web to the bulkheads and skin. - Clecoed and drilled the F902 bulkheads. Opened up rudder cable holes. - Did NOT rivet nutplates, yet. Will wait until F902 is disassembled and primed.
