7-30-2005 |
1.00 |
Fuel Tank Component Work |
Cleaned out inside of tanks w/ MEK and rags to remove all the "loose" Pro-seal I could get out. Installed ventline grommets and ran fuel level sending lines. Then installed fuel vent lines and secured outer capacitance probe plate. Trimmed sender line to final size and installed ring terminal. Ready to seal outer ribs now. |
