Date:    7-8-2005
Number of Hours:    1.00
Brief Description:    Rt Tank Rib Stiffeners
Polished and match drilled right fuel tank T405 and T410 stiffeners to the inboard/outboard ribs. Since I've decided to go with a flop tube on the right tank, I also drilled the 9/16" hole through the inboard rib-stiffener assembly for the fuel line fitting.
