Date:    3-2-2005
Number of Hours:    1.00
Brief Description:    More spar nutplates
Attached the K1000-4 center section attach nutplates per DWG 11 and 10A for both wings. Also, laid out the dimensions and holes for the 4 W-726 tie-down spacers and drilled the match hole for both W-731 tie-downs. I need to get a 1" diameter hole saw to cut the lightening holes in the W-726 spacers.
