12-5-2004 |
4.50 |
Rudder Riveting |
Completed riveting skins to skeleton except for trailing edge. Was able to squeeze most rivets, but had to buck some towards the trailing edges. Decided to pop rivet the last two rivets on the trailing edges as, but ran out of pop rivets...ordered more tonight. Fabricated the angle stiffener for the trailing edge. Epoxy'd the trailing edge wedge between the skins and aligned/secured with angle stiffener and clecoe's. Will cure overnight in the basement. |
