Date:    11-12-2018
Number of Hours:    5.00
Brief Description:    Wiring of Skyview Display Harnesses
Spliced together the Pilot and CoPilot harnesses for the following systems:
- GPS (power, ground, serial TX, serial RX)
- ADSB-In (serial TX, serial RX)
- XPDR (serial TX, serial RX)
Started figuring out how to splice together the VP-X serial connections. This will be much more difficult as VP-X manual calls for using 3-conductor shielded wire running into the DSUB hoods. I will have to pull the existing wires from the harnesses to do this.
