Date:    1-26-2009
Number of Hours:    2.50
Brief Description:    Sec Final-31
More property management meetings this am. Got to the airport @ 1 pm. Had some touch up sanding and prepping to do on th epilot side panel. Then sanded both panels w/ 220 grit. wiped the surfaces clean. them got out the interior paint, and set up the spary gun. I put the pieces outside the hangar, and closed the hangar door to avoid any overspray getting on the airplane. After spraying the second (copilot) panel, I got a phone call from my son Pat, and while I was talking to him a gust picked up the piece and deposited it on the asphalt!!!! &^$#!$#%^!!!. So..... I used some reducer and some Toulene, to remove the fresh paint (and the primer). Dried everything carefully, reprimed and then repainted the copilot panel. 9this time I put a screw in the panel to hold it to the paint stand!!!!
