Date:    1-7-2009
Number of Hours:    4.00
Brief Description:    Sec Final-23
Yesterday, I reassembled and then installed the center console (hopefully for the past time until the conditional insp). Then installed the Autopilot,switches, and trim indicator panel into the console. I needed to add a couple of Dsub shells to a couple of connectors. It appears that everything works after being installed. I also 'centered the control sticks. When I initially put the control linkage together I didn't get the sticks parallel, so today was the time to fix that, I ws surprised at just how much adjustment it took to bring them parallell. I ended up with the rod ends almost fully screwed into the hex tube.
Today, I installed the radio stacks and tested, AOK, The Defrost fans weren't working, so I trouble shot those. Turns out the problem was with the grounds. (I had them grounded locally to the fan/plate. I disassembled them and cleaned all of the paint/primer off the connection points, and did the same with the screw holes on the glare shield, I tested them and found them to work then installed then (hopefully for the final time). These don't push out a lot of air (they're PC fans), but they are quiet and should help remove some of the heat from behind the panel.
The last task today was to inspect / remove / replace/ the structural screws that hold the door hinges to the cabin cover and retorgue them. I've got to recheck the hardware on the gas struts tomorrow.
