Date:    1-5-2009
Number of Hours:    3.00
Brief Description:    Sec-Final-22
I picked up some flexible hose from Ace to connect to the lower portion of the breather tube...... BUT...... there's not enough room to make a bend and to clear the exhaust hanger bracket. After talking it theough with Jerry and Mickey, I think I'm going to reverse the adel clamp on the lower poertion of the tube, that should move it over to clear the exhaust, I'll also probably make a bracket so that I can mount the adel clamp higher on the tube. I'll get a new tube and reinstall . I need to move the breather tube Up 1/2" so that I can better clear the motor mount and the oil filter. I finished connecting the TCW power optimizer for the Primary EFIS, so I can keep it running during engine start. I may also add an oil pressure annunciator light. so I can start without having the EFIS powered up. I remade the fuel line from under the right seat out to the wing tank, as I found a kink in the old line. Then I installed the fuel & brake capture brackets under each seat to tie down the fuel and brake lines. Next step is to install the cenbter console and it's switches and th autopilot.
