Date:    7-18-2008
Number of Hours:    1.50
Brief Description:    Sec Paint-2
Not a lot to do while the plane is at the painters. Actually that's really a GOOD thing as we're in the middle of the Arizona summer now. But I do have some misc items that can be addressed occasionally. The interior close-out panels have been primed but not painted. Most of these panels will be covered in some type of upholstery/interior covering, but there will be some portions that will be visible, so today was a good time, as the summer monsoon backed off and the air dried out a bit. I also had a little body/repair work to do on the upper aft baggage bulkhead where I had over trimmed for the Ohead console and spliced/riveted in a piece of alum to fix. I filled the joint with bodyy/filler and sanded smooth. took a scotchbrite pad to all of the primed surfaces and then wiped them down with a tack rag. gace them 3 coats of the Sherwin williams Ultra interior paint, and left them to obake in the sunn for the rest of the day.
