Date:    3-28-2008
Number of Hours:    3.00
Brief Description:    Sec Home-47
Finished filling and sanding all of the empennage fairings and filling all of the 'dings'. Generated a LOT more dust. I decided to fill the rivet lines for the nose ribs on the Horiz Stab. It seems to me that these ribs are slightly undersized, and when riveted there is a noticible although slight depression in the rib rivet line. I've looked at a lot of RV-10's @ OSH and have noticed that all /most of them seem to show the same thing. So, I'm going to eliminate the problem with body filler and elbow grease. Found several more dings in the Horiz stab, seems like most of them were on the underside, I debated about whether to fill them or not, but, since I'm not in any realy hurry , Why not? Moved the Horiz back inside so I can give the garage and the plane a through cleaning tomorrow. Next week, I should be able to reattach the empannage and install the last fairing, nutplates and install the CNC trim cable brackets on the cover plates. Remaining items before paint:
1. Install Rosen visors
2. Enlarge wheel pants tire clearance for consistent 3/8"
3. Flox antenna holes in Cabin cover
4. paint inside of cowl
5. Paint door frames
