11-24-2007 |
3.75 |
Sec Home-27 |
Got off to a good start today. David McNeil another -10 builder, flew over from FFZ and picked me up @ DVT in his Glastar for a trip up to PRC for some breakfast. We had some gusty winds today and the ride up was a little bumpy, but the ride back was better. THANKS Dave! Back @ home, I finished installing the baggage compartment light and it's switch. Cut a hole in the Ohead for the switch and enlarged it to size using hand files. Made a trip to Auto Zone and picked up an inline fuse, installed a 2amp fuse in it then combined the Ohead light and the front and rear seat circuits into a single circuit that will be driven off the bus attached to the Aux battery, and we're in business. In order to wire the headsets and mics for the rearseaters, I needed to splice on some additional shielded wires to the ones coming off the audio panel. Added enough to each (R&L) mic to reach the rear seats. and then spliced two added cables to the 'pass' headset cable coming off the audio panel. I'm not sure exactly how I'm going to route the Left side rear pass cable from the right side yet, maybe back and across inside of the rearseat crossmember. Tasks remaining re. wiring prior to attaching wings. 1. route and wire headset jacks. 2. connect tail light to nav light switch wire. That's all I can do until the wings are installed and I make those connections. |
