Date:    9-8-2007
Number of Hours:    7.50
Brief Description:    Sec Home-10
I finished up the XM weather installation. The problems I had were due to not having activated my own account. with that done Thurs pm. Fri. powered everything back up and it works. Initially I had a problem with reception but I believe it's because i'm using 50ft of rg58 for antenna, and the db loss is too much. Since OP Tech doesn't support all of the overlays yet, I opted for the Aviator LT package, I can upgrade when/if OP makes the enhancements. I fixed some 'bugs' in the dimmer circuit, and added some 'miniturized' d-sub 9 pin connnectors to the 26 awg Ray allen trim indicators. I used the method in Bob Nuckols AeroElectric connection. Sat I set out to wire the annunciator panel lights. I've got each respective light wired or labled/tied off to it's source. The next task was to complete the wiring harness for each of the rocker switches. That required a quick trip to Aerozona for more wire! I also wired the Starter/Crossfeed; Main Master; and Aux Master switches. I've labled and routed all of the wires to either the left or right side and have the left side all tied and secured w/ Ty-wraps. There are a couple of sub-bundles that don't go left/right but go to components mounted on the upper fuse subpanel. Those got tied into bundles and labled to get connnected when the panel gets physically installed.
