Date:    8-11-2007
Number of Hours:    3.00
Brief Description:    Sec Home-1
Trying to close up some loose ends today, It's too hot to tackle anything major. replaced the Exhaust hangers with the ones that John Forsling sent. These have a metal bracket that attaches to the exhaust end. John requested I replace the old ones with these. Also at his request I mounted them with just a slight bit of tension on them, rather than with some slack as I had previously done. I completed all of the Throttle Prop and Mixture linkage control rod end connections. And then made a quick run to Aerozona for some large #4 cable fitings so that I could mount and connect the current limiter for the Main elec system. The Auxcurrent limiter gets mounted closer to the battery, aft of the baggage bulkhead.
