6-15-2007 |
1.50 |
Sec FF4-Finish |
Finished the last of the Fule hoses. While preparing the # 5 Baffle for final riveting, I drilled a hole for the fuel purge valve return line. I put a rubber grommet into the hole and then threaded the fuel return line through it. Mounted the # 5 engine baffle, and then attached the return line to the purge valve and to the firewall fitting which runs back into the right fuel tank. |
