Date:    4-7-2007
Number of Hours:    4.00
Brief Description:    Sec PP-3
Late last night, I decided that I would eliminate the side air vents for the rear seats. I've already got fresh air for thee seats in the overhead console. and These side vents look like a good source of water and air leaks. It was also going to be a pain to get everything faired level and looking good. So today I drilled the rivets out from inside the fuse and then used the old doubler to make .032" cover plates. I had already applied a heavy coat of flox to the opening so I countersunk through the flox and well into the .032. I used CS4-4's and attached the cover plates. then began the process of sucessive layers of fillin gthe void and rebuilding w/ Flox mix. I also got a single ply of fine weave fiberglass tape applied around all of the windows. I used the lay-up between to sheets of plastic sheet and then cut 1" wide strips (on the bias) and applied those to the pre-wetted window perimeters. It worked MUCH better than my previous attempt. I really HATE this part of the build. the garage is a mess, as is the plane, and there's more ahead than behind at this point. Oh well! complaining won't get it done, better stop whining and get on with it!
