Riveted the Hinge to the nose leg fairing, then decided to start on the paint prep for the wheel fairings, Sanded the nose wheel halves and then taped on some saran wrap as a release age3nt to the front halve. Screwed the two halves together and then applied liberal amounts of SuperFil to the Nose wheel fairing, I tried to fill as many of the large pinholes as I could, but it will take another squishing effprt before they are ready for Priming. Also put an initial coat on the intersection fairings. Put them all under the lights to cure overnight and will sand and continue tomorrow.
