Not a lot of energy today, worked in several small increments. (all of this getting up and down from the ground dosen't make it any easier) First off got the Right gear flox build-ups on the pants then put them under the lights for a quick cure. then had to fill several voids in the Left forward flox build-ups. Meanwhile did the build-up on the Left rear gear pant for the axel attachment. while that was curing, I drilled and attached the nutplates to the fwd portion of the Left gear attach bracket. Cleaned up the Excess flox that spilled over the edges. Then pulled the Right fwd pant, it turned ut better completely filled, then did the flox build-up for the Right axrl attach point, put it back on the lights. After it hardened sufficiently, I poped the washers off both rear pants, there were a couple of voids that needed to be filled, sanded the washers and floxed then back in place, this time 'locking' them in with a flox build-up around their perimeter. That's it for tonight. tomorrow I'll finish off the nutplates that connect the fowd and rear sections and then finalize the mounting holes. If there is time left I'l start on the leg fairings.
