Date:    12-1-2006
Number of Hours:    3.00
Brief Description:    Sec 45 Door gap fix session # 8 both doors
Same old story, filling, curing, sanding, ... repeat.... It is getting close to the end of the Flox/Fill esisodes, I think i've got enough of a build-up on both doors to get them flush with the Fuse sides, without body filler. After sanding flush tomorrow, there are a couple of spots where the gap is a little too big for now, so a little more filler there and then I think that part is done. The next step is to remove the doors (again) and fill then with SuperFil, sand them and then shoot them, with Smooth Prime and final sand then. the right door will need a repair where I cut the handle too big. Then I think I'll also prepare the Cabin cover, to get ready for paint (I'm not close to painting) I want to get as much of this Major sanding and filling out of the way before the engine arrives. I've still got some repari work to do on the inside of the doors, but haven't decided if I want to do it now, or when I install the interior, headliner and side panels. The Super Fil over the Flox on the Cabin/Fuse seam worked great, It sands NICE!!!!, applied a couple of touch up spots which need to be sanded out and blended, then I'll re-prime that area.
