This is starting to sound like a broken record, Sand, mix flox, apply, wait to cure, sand, fill........ more of the same tooday, I think that the Right door is pretty good, I'll remount it tomorrow after the morning sanding and check the clearance, The Left door will probably require one additional touch up after tomorrow. Additionally I had my 1st experience with SuperFil today, its a Lot thicker than I though almost like putty, which makes it a bit easier to work with than epoxy / flox / micro etc. It says it will adhere to any clean surface including alum. I sanded the Flox seam between the cabin cover and the Fuse that I aplied yesterday, and then applied a layer of SuperFil over both the right and Left doors. I'll let it cure overnight and we'll see how well it sands , it will probably require a 'tough-up' application following this, I'm trying to get all of the duist generating stuff done by Sat, but I've still got some work on the door skins themselves around the handles I installed and a repair where I had to cut out some of the door to make room for the latch lever's.
