More of the same, did the initial sanding of the Left door, then removed the door, this door sits lower than the cabin top in a couple of places so it's going to require several tape/fill/sand cycles to get them booth at the same level and smooth. After the initial sand I mixed up the goop and applied to the cabin areas that needed some build-up. have a couple pf places on the right door (not shown) where I also did smoe minor build-up's after they are cured that should do it for the Right door frame portion, If this sits up hard enough tonight I might be able to get another sanding done on it and then get another build-up applied so it can cure/harden on Sunday. We'll see.
