1st thing this am I made a 40' RG58 cable so I could put the GPS antenna outside where it could get a cleaar view of the sky. It made a big difference and I'm now able to get all of the GPS data and the terain displayed. Next task was to replace all of the Faston connectors on the rocker shitches with the smaller /correct size. Got that accomplished and then layed out the dimmer circuits for all of the panel /rocker lights. I'm going to put rocker switch lights, audio panel, Transponder, & NavCom's on a single rhiostat. I hooked up a representative sample of the above and tryied out the switch I received from Perihilion. I'll have another for the eyebrow lights and another for the swivel/map LED lights. Hooked up wiring for the Compass light (included on dimmer circuit, and the Davtron clock/timer. Spent the rest of the time tidying up the harnesses. It's starting to look a bit cleaner in the back, (if that's possible). Not that i've got the dimmer wires seperated, I'll l need to cut the holes and mount them in the panel.
