Date:    4-21-2006
Number of Hours:    3.25
Brief Description:    Sec 29-18 clean-up
Thought I'd finish up Sec 29 today, Torey was home this moring so I had some bucking help. was able to get the fwd side skins riveted all EXCEPT the las 8-10 rivets that are on the aft end of the F1041 longerons. There is a triangular doubler that gets instaled in here as well, the big problem is there's no room to get any of th ebucking bars that I have in to do the job#$@#$%#@!!! . not sure how to do this I'm reluctant to put all pops in there as a part of this is to tie these 2 pieces together, I may need to buy a special purpose bucking bar and WAIT (which means that Sec 29 will remain UNFINISHED for a little longer.FURTHER - I discovered my stupidity in that I went ahead and installed the landing gera mounts -----------, well it turns out that you need to install the floor pans BEFOR doing that, SO --- spent an hour removing one side gear mount. ! step fowd, - 2 back!!!OH well!
