Date:    3-17-2006
Number of Hours:    2.75
Brief Description:    Sec 29-5 steps 1-4
Bent the Aft Fuse skins both L&R. The plans don't say anything about bending the Left (but it's just a repeat of the Right, after the confusion with the .063 angle, remade the construction angles out of .125 and the bend went right in. It takes a pretty good twist to get to 60 degrees, and After clecoing on the skins to the fuse it probably could go a little past 60, I added 5 degrees for the Left and that was still a little shy. All in all it went much easier that I had heard, after fretting over the Righs skin, the Left went in in about 30 minutes.This is a rewarding step because the Fuse now has some skins on it and it's beginning to look like it might be an airplane some day!!!!!!!!!
