Start to work on the Fuse bottom skins. Pealed the Vinyl, I found I had a problem , I assembled the Fuse bulkhead assembly to the Rear seat ribs abd DID NOT get the aft flange of the 1018L&R outboard seat ribs on the OUTSIDE of the bulkhead, I thought i was going have to drill out major portions of the bulkhead and the1018 ribs. BUT I was able to bend the 1018 ribs enough to get them free and on the outside of the bulkhead end flange. This allowed me to cleco the 1021 ourboard baggage ribs between the 1018's and the bulkhead per the plans. Whew!!! close call, it added some time , but not as much as it could have. The 1021 baggage ribs on the plans show that there should be a joggle on the forward end of the ribs where they meet the 1018. I checked a couple of other builders web sites, and found that their ribs were the same as mine (No Joggle) so I proceeded, as near as I can tell it shouldn't be a problem down the road when the side skins get attached. Clecoed the rear seat floor stiffeners. Then clecoed both skins to the rib assembly, then match drilled all common holes. And reamed the #30 holes on the top of the floor stiffeners.
