3-12-2011 |
3.00 |
Engine Installation |
Installed lower mounts which took a bit of effort. The holes were not perfectly aligned so I had to use a "bullet" and drive it through and follow it with the bolt. The bolts were AN 7/16 27 Bolts. I torqued the isolator bolts and airframe to dynafocal mount to 255 in lbs. |
