Date:    2-26-2011
Number of Hours:    7.50
Brief Description:    Engine
Using some .040 mild sheet steel, I fabricated a bottom for the battery box. I also fabricated hold down guide tubes and welded those to the side of the box using som 3/8 tubing. I also began laying out backer plate for attachment points and clamp attach points; Prepared for and installed nut plate on backer plate for the battery box
