2-12-2020 |
3.00 |
Installed Table Top on to Work Stand |
Used the Fusulage cart as the bottom of the work bench. By using a 2.5" edge around the top I get a place to clamp to, it allowed the 2"x8" boards to sit on the work cart. Yes I took one quick measument and all worked out as if I had spent hours planning it out. Used a step stool to rase one end it happend to be the exact hight needed to level out the table. When Lois rolled the cart under to the middle she put it dead center first try with out any marks to place it to. Some times its better to Measure once and Luck out a lot. |
