1-12-2020 |
6.00 |
Mounted Landing Gear and Tires |
Moved engine to back of garage Drilled holes in plate used grinder to cut rubber mounting dampers seperated wheels to mount tires mounted tires glued brake disk spacer to hub for easyer assembly only mounted the front wheel because I dont have enough room to store evey thing in garage wiht the wheels on |
