11-16-2019 |
6.00 |
Glare shield instalation |
Match drilled Glare shield 75F16-2 Cut to fit around frame Debured Coated with Cortech and installed with A5 Rivets Installed insterment panel to get alingment correct. This was extremly diffucult to get the panel inside the lower sheet metal it took alot of wiggeling and taping to get it to aline, and was worse after adding corosion protection. |
