3-27-2009 |
0.50 |
HS 909 Shims |
Fabricated the two HS-909 shims from AS3-040 stock and match drilled them in position on the front spar (I actually made three sets before completing a set I liked). When I match-drilled them in place the holes were off-center. On the last set I drew a center-line which I lined up in the center of the holes before drilling. This approach produced a nice set of shims with straight holes. |
