7-25-2005 |
3.00 |
Fiberglass work |
I decided to fill in the ends of the control surfaces. I will fill most of the void with styrofoam and use F/G with filler to provide the finished surface. I used balsa wood covered with F/G to make the filler blocks in the HS and VS fiberglass tips.My wife got some new outside lights - and fortunately they were packed in aircraft grade styrofoam :-) |
