6-17-2014 |
0.00 |
Installed capacittor to dampen noise on fuel press |
After experiencing large fluctuations in indicated fuel pressure, with associated alarms, researched the problem. Found others had experienced same issue. Called Dynon and got their recommendation to place capacitor of approximate value 330 mf across sensor output. Bought 470 mf cap and installed, Problem solved. |
