Date:    2-13-2012
Number of Hours:    0.00
Brief Description:    Finished mods, began inspection.
Set up for balloon test. First test failed due to bad connection, second test lasted through afternoon. Added foam to access panel gaps. Reinstalled G496. Tested iPad into music input.
Removed more cover plates, started inspection checklist. Removed, cleaned, checked gaps in sparkplugs. Checked magnetic plug, found only small amount of very fine powder.
