Date:    4-8-2013
Number of Hours:    2.00
Brief Description:    Wired wings.
Sam helped me find the strings and pull the two new wires through the wings. Then like a dummy after lunch I pulled the wires in the left wing back out of sight at the wingtip. Drilled an extra hole and fished them out, with difficulty. Crimped on pins and tested. Found I had reversed two pins on right wing root, 7 and 8. Got 8 out, couldn't budge 7.
