Date:    1-6-2011
Number of Hours:    3.00
Brief Description:    Readied right wing for installation.
Took second low workbench to FBO hangar. Moved wing rack to open work area. Moved right wing to workbenches. Installed the right flaperon. Re-intalled navigation light and landing light. Installed the rivet I had left out of the upper tiedown hole. Cut off tiedown eyebolts and installed on right wing. Moved wing back to the rack.
Took left wing off the rack and put on tables. Just then Dominick called and needed me to go to 5B2 with him to give remedial instruction on the VOR approach so he could finish his instrument test. Replaced wing on rack and helped Bill and Tom reshuffle the hangar to make room for the '12 in the front with enough room to put the wings on.
