1-8-2011 |
2.00 |
Filled pin holes - again. |
Started a fire in the shop stove and then cleaned up the 6 inches of snow that fell yesterday. Mixed up a small batch of thickened epoxy and coated all the pants once again. Thought we had these completed before but a few hundred pinholes showed up when we primed. Tomorrow I'll retrieve the sander from the airport and start sanding again. Taped off the electrical connection panels that I did not paint because I thought they wouldn't show. Tomorrow I'll go to Walmart and pick up a rattle can of some off-white paint that is close to the white on the fuselage. It'll be good enough for now - Rob and I can hit them again with the real stuff next time we mix some up, if this doesn't look OK.. |
