2-21-2010 |
7.00 |
Finished landing gear, worked on canopy. |
Hit the shop early and did some catch-up tasks, that resulted from last nights VAF and builder blog research. Installed the retainer nut on the nose wheel valve stem, reoriented the axles for vertical cotter pin orientation, and primed the nose fork. David came up about 8:30 and we mounted the main wheels and brakes. Then installed the nose gear and lowered the airframe onto the gear, with castored dollies under the mains to facilitate moving the project around. Later I put all the tools away and cleaned the shop. Then started cutting away the rough edges of the fiberglass layup, using the dremel tool and a cut-off disc. |
