11-15-2010 |
4.00 |
Bled brakes again, worked on PAP tasks. |
Went to Post Net for updated Dynon manual, stopped at FBO to pick up quart of brake fluid. Worked on brakes again. Thought I had all the air out several times - but didn't. Finally got it out by loosening the connectors on the bottom of the master cylinders and pumping the air out there. Tightened up the screws that hold the back of the glove box. Ran the autopilot configuration again using the Version 5.4 manual. Went through the remaining "G" sections of the PAP, performed everything that I could. |
