10-1-2010 |
6.00 |
Finished tail cone fitting. |
Worked all afternoon on getting a good fit on the tailcone. Had the stabilator on and off several times. It gets easier after you learn a few tricks. Ended with a good fit and specified clearances. Took about 1/8" off the metal on the bottom of the stabilator. Installed the nutplates and riveted in place. Test inserted all the mounting screws. |
