6-25-2010 |
2.00 |
Retorqued engine bolts, worked on cowling. |
Flew to New Hampshire with Mark for currency in the 182, was back by noon. Dealt with a couple issues with Mom (recovering from kree replacement), then got to the shop for a couple of hours. Loosened up the four engine mount bolts, wiggled the engine around, and re-torqued. Installed screws in the deck over the avionics bay to be sure the firewall was in the correct position. Cut the cowl hinge pins to length and made the knuckle cutouts in the top cowl. The cowl at the juncture to the spinner is still off center a bit. Been thinking about how to correct it. |
