Date:    6-19-2010
Number of Hours:    4.00
Brief Description:    Mounted prop, worked fiberglass.
Flew the Arrow down to Cooperstown this morning to join a bunch of my flying budies at the pancake breakfast. Got back to the shop around noon and sanded the second coat of epoxy off of the cowl halves. Used the Norton 120 paper. Boy, this pinhole stragety of 3 coats of pure epoxy sure is a lot of work. I hope it works. The pieces that have had three coats still have some holes showing.
Pastor Pete stopped by for a visit and then I got Carolyn up to the shop to help mount the prop. Clamped the spinner in place for the rotation alignment checks.
Two concerns after today. There is a lot of resistance to turning the engine over. Starter drag? The prop adjustment doesn't seem right, only a one mark range.
