5-23-2010 |
2.00 |
Met with Rob, worked the fiberglass. |
Rob Faulds came over in the PM and we discussed primer/paint options at length. He also gave me a lot of tips about block sanding on the canopy fairing. I'm going to get my paint through Rob and he is going to get me the sanding primer for the fiberglass parts first. Nice guy. After Rob left I finished sanding off the previous epoxy coating from the cowling halves, and shaped the canopy fairing better using the long 80 grit blocks I made up some time ago. The 45 degree sanding worked good and I got out some of the humps that remained, especially on the right side. |
