Date:    5-21-2010
Number of Hours:    2.00
Brief Description:    Tested avionics and trim.
Plugged the pitch trim servo into the tail and ran the trim motor tests. The end-to-end runs seemed to be in the right time range so did not change the potentiometer.
Tested all the avionics and all seems OK. No GPS signal in the shop so don't know if the GPS is talking to the Dynon. Autopilot lights up but it is not yet configured in the Dynon so no meaningful testing accomplished. Radio works great with handheld. Intercom fine.
