11-10-2010 |
5.00 |
Finished roughing fuselage, ran pitot/static tests |
Roughed up the whole bottom of the fuselage, done with ScotchBrite. Yeah! Found and inserted one missing rivet. Otherwise uneventfull. Hooked up the syringe and ran the required tests on the pitot and static systems. Had to tighten up both connections on the back of the Dynon in order to get acceptable lapse rates. The plumber's putty worked great, first try. Ran Dynon procedure to configure the autopilot. |
