Date:    10-28-2009
Number of Hours:    7.50
Brief Description:    Finished roll bar and aft bulkhead structure.
Got a full day in the shop, thanks to a monsoon rain all day. Mounted the previously prepared roll bar. It slipped right onto the mounting brackets even though I had torqued them down. Holes lined up quite easily with minimum persuasion. Riveted all 21 holes each side. Boy, that thing isn't going anywhere! Then prepped all aft bulkhead and roll bar support parts, and painted them before going to lunch.
After lunch I assembled the aft baggage bulkhead and associated parts. Lots of nutplates. Finished Section 24. Put away all the tools and cleaned the shop before quitting for the day.
Tonight I will check the VAF for advice on Section 29 and start that next.
