Date:    10-16-2009
Number of Hours:    2.00
Brief Description:    Began work on rudder/brake pedals.
Changed my mind on the fuel sensor bolts. I installed the -17's with two washers under the heads instead of swapping them for shorter bolts. From looking at Art Pennemen's log it looks like at least one of them gets replaced later anyway.
Began work on the rudder/brake pedal section. Found it necessary to clamp the assembly down to the flat surface with a couple pieces of plywood and long screws. That way they can't move during the drilling. Used a square to assure vertical position of the brake pedals. Drilled the first two as instructed.
Next - drill the other two and proceed with the tubing.
