3-9-2010 |
4.00 |
Avionics - EFIS, transponder, com radio. |
Repainted the middle and right side panels Sorted out the panel screws, used the good non-chewed up ones to mount the left side panel. Installed the Dynon unit. Heat shrunk the cable ends and installed the connector housings. Installed the transponder tray and transponder. Same with the com radio. |
