4-25-2012 |
5.00 |
Started working on rudder skins. |
Went to airport and cleaned off bench, stowed tools. Made another attempt to break loose the #4 cylinder/piston. No joy. Dumped in more penetrating oil and set aside. Matched up the new rudder skins that the boys had corrugated for me, drilled some tooling holes and clecoed (later riveted) the sides together. Figured out the rivet patterns and marked skins. Put it all away for tonight. |
